GPS mount for side console
Discussion in 'Power it up with Electronics' started by Alex M., Apr 18, 2017.
  1. Alex M.
    Alex M. Active Member
    20
    37
    43
    Looking for suggestions for those that have a skiff with side console. How do you mount your GPS? I have a HB waterman and am trying to figure out the best way to mount the simrad go7 I just got for it. Thanks in advance!
  2. Egrets Landing
    Egrets Landing Well-Known Member
    112
    49
    103
    Put it on a beefy RAM mount an attach the mount to the console where it makes the most sense. That way no matter what you may elect to switch into in the future you wont have to mess with a new mount install and console hole repair. Also, provides maximum flexibility for viewing angles.
    Alex M. likes this.
  3. fjmaverick
    fjmaverick Well-Known Member
    802
    255
    198
    RAM is having a 20% site wide sale right now.
    Alex M. likes this.
  4. Alex M.
    20
    37
    43
    Thanks for the reply, I was thinking a ram mount but my mechanic who is installing the gps says they won't hold up running in chop. Have they held up well for you?
  5. Mike C
    Mike C Well-Known Member
    204
    104
    118
    Mine has been just fine. Have used it on the Gheenoe and my Tailfisher
    Alex M. likes this.
  6. Egrets Landing
    112
    49
    103
    I don't know what that means... "it wont hold up". I have been running 12 inch screens on a RAM mount for more than a couple of years with no issues on an open skiff and they probably weigh twice as much as the 7". Maybe it wont hold up if you get a wimpy mount. If you get the larger sturdy RAM model its more than adequate and holds up fine. They make different size arms and balls and attachments depending on the intended application. You can tighten that thing down solid to hold any position. A tad less sturdy in terms of shake in chop compared to a direct gimbal mount to the console, but nothing that I notice that bothers me. Much of the time I have my hand on the corner of the unit anyway which further stabilizes it. The disadvantage to the direct gimbal mount to the console is much less versatility in unit position and viewing angles and viewing height and having to do likely console repairs down the line when you change units and gimbals again. You could even mount a RAM to a vertical console surface and bring the unit to positions over the console.
    Alex M. likes this.
  7. Alex M.
    20
    37
    43
    Thanks for the reply, he is saying hat based on his assumptions so I wanted to check with people with experience on here.
  8. Mike C
    204
    104
    118
    The Ram mounts are sized differently hold certain units.
    When I bought mine, my GPS unit was listed on the packaging as being the correct fit. Go to your local BPS or Cabela's and look at what they stock
    Alex M. likes this.
  9. kensfl
    kensfl I Love microskiff.com!
    40
    10
    333
    Alex M. likes this.
  10. J Jones
    J Jones Active Member
    17
    11
    28
    I have a side console and use the RAM mount for my Lowrance 7 Elite. No issues what so ever.
    Alex M. likes this.
  11. Alex M.
    20
    37
    43
    Just ordered a ram mount, thanks everyone for the help
    J Jones likes this.
