got a new model TT2A tinytach but give me problems,,,,,,,,
9375 22
I just recieved a new tiny tach TT2A model for my 15hp merc 2-stroke and they doesnt make "2C" model anymore. Now they make a tinytach and adjustable degree reading for lawn mowers to a V8 engines. I dont know if my motor has 360 degree 1 spark per revolution or 180 degree 2 sparks per revolution. :-/
I tried everything with good connecting ground wire and clean the spark plug wires for better reading.....still nothing. I havent tried this model before.. I never had a problems connecting with 2C models.
does anybody tried this model before? I'm going to ship it back and get another one. MAybe this one is faulty tach..
1 - 20 of 23 Posts
me and forum memeber"luv2flyfish" have both had problems with our tt2a's :( we had to send them back to have filters installed because evidentaly the mercs have a hot spark that over rides the unit, atleast thats what we were told :-? was talking to capn ron yesterday about the accuracy of these things and the jury is still out for me :-/ firecat has had problems with one he got yesterday too :mad: i have mine set up slightly different and hope to hit the low tide this afternoon so i can test it and compare :cool:
Got snook?
I installed mine yesterday on my 04 15hp merc and it works fine. I just wrapped the top plug wire about 4 times as close to the plug as possible. If I wrapped the plug wire close to the coil I got funky readings. I set mine to 180 degree.
Yep mine works like crap too :mad:. I tried everything I could think of including 6 different ground points and wrapping every which way possible for 3 hours.
It's just a crappy prodcut in my opinion, I'll be returning mine tomorrow. With no real time data there is no way possible to see if it's accurate, the think could be off by 2000 RPMs and you would never know. I'm going to look into a standard type anaolog tach next.
Won "Do More With Less" Award!
Yeah it's sucks..... I miss the "2C" model tiny tach unless somebody wants to sell me one.... ;D
I guess I'm going to ship it back and try another tinytach with filter or is there any different tach I can find? Like a tinytach?
Living & Dying in 3/4 Time
I like the description on the sendec, where it says it works with all 1 cylinder engines and may work with most 2 cylinder engines, then further says it Might work with some 2 cylinder outboards ::)
is there no other options for real tach?
I just found out that yamaha makes it's own tiny tach type guage, but specifically made for use with 4 stroke motors. After I return my tiny tach tomorrow I may order it.
http://www.boats.net/parts/detail/Accessories/Y-ENG-METER-4C-02.html
will pole for food
Note: the 2A's dont work on 2stroke Yamaha's either. I just got my tach back WITH a filter...we'll see how that goes...
-whitesnooky- A technician at tiny tach suggested cutting the red wire shorter and only wrapping once...It made my unfiltered tach work a little better, but I would still call them back to get a filtered version.
I got the filtered version for my 03 25hp two choke, and it does not work properly. I just spent an hour trying everything I could think of including multiple grounds, wiring away from the coils etc... Tried it on 360 with as few as 1 wrap and as many as five wraps. Tried it on 180 with single up to triple on both wires and still it is off. I get readings that go from 000 to 600 and all in-between without ever changing the engine speed.
My verdict is in after having to send it back twice. Gimme my money back!!! :'(
Discussion Starter · #12 ·
X2,
I like to get my money back and spend on something else.
This is worst P.O.S I ever received! I wish they should know we need a "2C'' model and keep it that way...
I'm not very happy with TT2A model at all......
Now I can screw them and find me a different tach from now on... :-/
ok so i've been out several times in the past week or so and all indications are that mines working as it should :eek: seems to register idle rpms ok as well as top speed rpms so we'll just see what happens but if this thing starts giving me any problems i'm taking a hammer to it :eek: :D ;D ;)
well here we go again fellas :mad: dang things been working fine untill yesterday while coming in i noticed it not reading correctly :mad: when i wiggled the wire going in to the unit it cleared up but let go and it starts messing up again, i'm calling them tomorrow :mad:
As many problems as ya'll been having,
what with fighting to get these tachs to function,
has anyone called the outboard manufacturer
to ask what they use to monitor the outboards?
at this point i would probably take my money back if i could get it without a fight, i've dialed in the prop as good as i need it to be so dont really need one but they are cool to have, certainly these units are not all thats available to the public??? :-/
at this point i would probably take my money back if i could get it without a fight, I've dialed in the prop as good as i need it to be so don't really need one but they are cool to have, certainly these units are not all that's available to the public??? :-/
If you want to verify with one of the "old" tinytachs, let me know and I'll send you mine. And you should raise hell with them to get your money back!
pm sent :cool:
1 - 20 of 23 Posts
