1 - 3 of 3 Posts
Gheenoe Classic with 1998 9.8 HP 2 stroke Tohatsu outboard and magic trail trailer. 1700 dollars. Located in Jacksonville.
Motor runs perfect and has recently been serviced with new pistons, rings, carb, water pump etc at a cost of 900 dollars.
Trailer received new 8 inch wheels 6 months ago with galvanized rims.
Galvanized hubs and new bearing and seals were put on 6 months ago.
Working navigation lights and 12 volt battery included.
Two swivel seats
Trolling motor mount on bow
Two flush mount rod holders rear, three rod rack in middle and 2 plier holders
Center seat has area has standard livewell and storage areas beneath
2 life preservers, paddle, whistle, 20lb anchor with 50ft of rope.
Tie off cleats front and back
*This boat hull has been patched with fiberglass mat. The front of the boat had two holes about the size of a nickel. The patch is not attractive, but the boat has been in the water 40 times in the year since it was patched and the boat does not leak at all.
1 - 3 of 3 Posts
