1 - 20 of 37 Posts
Hooking Lips is my life
ok took boat out today ran perfect. turned it off fished for awhile went to start it and it would not open to wot like one cylinder was not working. I already changed the coil packs thought that was the problem now what do yall think to check next :(
idled all the way back to ramp and right before ramp the other cylinder fired
1.start the the motor at night w/ the cover off and see if u have any arcing
next jiggle all the wires w/an insulated screwdriver
again looking for arcing
2. check your water/fuel seperator for water
start there
loose wire , stator or trigger loose or going bad... electrical is a mo fo on o-boards!!! how old are the other electr. parts ???
   -a
whats a trigger?
1989 merc 35 im at a loss I think that is next for me but wife is going to kill me
Are u sure it is electrical and why?
If so >>>clean ur ground on the coil on what u think is the offending cyl.
I HAVE HEARD that a power pack can be bad and cause the same prob. but rare
I will put a $ that it is a bad plug wire or plug
do the simple inane stuff first
Repeat >I love my boat  ;)
I would ck the wire things and if does show anything wrong change all the coils and their wires--they are probably the originals
if u want send a pm
1 - 20 of 37 Posts
