1 - 4 of 4 Posts
Used, but in very good condition. New price was about $135. This winch came off of my custom Ramlin Trailer and is less than 3 years old. Rust-resistant, cast aluminum frame, fully enclosed winch with adjustable handle length and configuration, an easy-to-use pawl-engaging lever and a dual-gear drum. Strap included.
Features:
  • Completely enclosed design is durable and stylish
    • Cast aluminum frame provides corrosion resistance
  • Aluminum, soft-grip handle offers ultimate adjustability
    • Switch from right- to left-hand drive configuration
    • Adjust the handle length to 6" or 7" to balance torque, speed and clearance
  • Quick and easy installation with Fulton's Easy Install System
    • Fits industry-standard mounting pattern
    • Includes necessary hardware
  • Easy-to-use lever engages and disengages pawl
  • Dual-gear drum and solid drive gear allow for smooth, reliable operation
  • Handle can be turned in reverse to slowly let out strap instead of freespooling
    • Freespooling option available
  • Rear strap guide helps to prevent strap from making contact with gears
    • Strap with hook included
Specs:
  • Handle length: 6" or 7"
  • Gear ratio: 4.1:1
  • Hub diameter: 0.65"
  • Drum storage: 20' long x 2" wide strap
    • For use with strap only
  • Weight capacity: 1,600 lbs
  • Limited lifetime warranty
I am located in South Florida. Given the weight, local pick up only unless you pay the shipping.
1 - 4 of 4 Posts
