Fuel overflow valve
Discussion in 'Outboard Maintenance' started by permitchaser, Jun 17, 2017.
  1. permitchaser
    permitchaser I Love Skinny Water
    3,061
    484
    1,688
    I have had a black plastic one on the side of the hull since I purchased my boat 3 -4 years ago. Last summer I lost the cap. My theory is since its about dock height I probably nocked it of waiting to load tied to a dock
    Anyway I met with my marine mechanic and he ordered a flush mount stainless one. He said I might get water into my gas tank the way it is:eek:
  2. DuckNut
    DuckNut Brandon, FL
    4,657
    499
    1,938
    I hope your mechanic informed you that it was not a fuel overflow valve but rather a fuel tank air vent cap.
  3. permitchaser
    3,061
    484
    1,688
    your right
  4. State fish rob
    State fish rob Active Member
    80
    16
    33
    Fuel vent , but i have seen them spew before gas runs out filler neck from over filling
  5. permitchaser
    3,061
    484
    1,688
    Yep if it's a full tank and sits in the sun it will run out of the vent hose
  6. Smackdaddy53
    1,961
    1,796
    968
    Fuel Overflow Valves must be on the same shelf as Kanooter Valves, Blinker Fluid and Muffler Bearings.
  7. permitchaser
    3,061
    484
    1,688
  8. Megalops
    Megalops Rex Kwan Do Dojo
    1,226
    611
    978
    Just the other day snipe hunting I got 3. But I ain't cleaning 'em!
    Smackdaddy53 likes this.
  9. permitchaser
    3,061
    484
    1,688
    Did you take a flash light and a paper bag. Those snipes will bite you
    Megalops and Smackdaddy53 like this.
  10. permitchaser
    3,061
    484
    1,688
    http://www.attwoodmarine.com/store/product/fuel/flush-mount-vent
    My mechanic ordered this for me except it is a 90 degree bend. And of course its larger than the hole I have in the side of the boat by 1/4" So I went to Harbor Freight and found a drum sanding set that has sizes from 1/4" to 2". I used the 80 grit drum they provided and man it cut through in no time but it got dark as I got it to fit. I used a head lamp that I got for free by buying the $9 set of sanding drums. I'll put it together tomorrow
  11. Smackdaddy53
    1,961
    1,796
    968
    Gemlux has some nice ones too
