fuel Consumption Formula ?
2447 6
This was posted "elsewhere"
At wide open throttle an outboard will burn 1 Gph +/- 10% for every 10 horsepower
Does this make Sense ? for 2 and 4 Strokes ?
· Registered
This is conjecture and for discussion only. Assume you have a flat bottom boat with 700 lbs load and a 20 HP engine. At 3 mph you will get about 14 mpg. At 6 mph about 12 mpg - at 9 mph about 2.5 mpg - at 12 mph the mpg will increase to 10 mpg - at 15 mph it will drop to 8.5 mpg - and at 21 mph it will drop to 2.5 mpg again. I wish I could graph this as it would make a lot more sense, but the whole idea is your boat will be more efficient at hull speed and below. It will be least efficient as it climbs the bow wave or runs at max speed.
Frank_S
· Registered
so best case a 150 hp will burn 75 pounds multiply that times 6 hrs ....
leave the egrets and Yellow fins at home !
· > PRO STAFF <
75 lbs / 6.2 lbs per gallon = 12 gallons
Egret 16 has a 41 gallon fuel tank,
at 55 mph that gives you a range of about 190 miles
Throttle back to cruising speed and you'll probably get 250 mile range.
I don't see a problem Dave... ;)
· Registered
Probably be OK if you had a couple of passengers Kicking in
But I guess if you have a 30 K boat $120.00 In fuel should not be an issue LOL
I'm just used to running the smaller boat / Motor Usually 3 Gallons in the Gheenoe for a 2.5 Hr run ...
Dave
