SOLD/EXPIRED FS17 low sheer hull / custom Coastline Aluminum trailer
Discussion in 'Sold/Expired Classifieds' started by bboyet2, Nov 19, 2013.
  1. bboyet2
    bboyet2 Texas Coast
    28
    This is a custom FS17 Low Sheer composite skiff. Hull is marine grade plywood (no voids) completely encapsulated in epoxied fiberglass. Hull is painted System3 Whidbey White with a graphite bottom to prevent oyster rash. Boat is 16'8". Custom aluminum Coastline Trailer with LED lights and transom saver roller. Upgraded to Aluminum wheels with Aluminum spare. Trailer has never been wet! Hull is finished on outside. Front and rear casting decks are cut and fitted, just not glued in. Boat is set up and plumbed for center console. Installed custom built aluminum 10gal fuel tank. Installed rod tubes under front casting deck, definitely long enough to accommodate fly rods up to 10ft. Boat is rated by designer Jacques Martins for 50HP.
    The boat looks great and was built with utmost care and attention. I really don't want to get rid of her. Recently moved to Houston and don't have the time or space to finish. All the hard work is done. Finish out the decks and install a center console and you're good to go.
    Comes with gear to finish her out as well. Shark eye LED navigation lights, renzetti push pole holders, can talk about poling platform as well. Asking $6000. Boat is in Houston
    PM me or text/call with questions 318.282.zero zero 61
  2. Gramps
    Gramps Living & Dying in 3/4 Time
    2,558
    31
    903
    Sweet looking boat LSU, sorry you've got to sell her off! Did you post the building BBC? I love the versatility provided by the low sheer 17, by far the best looking utility boat in Jacques' lineup.
  3. bboyet2
    bboyet2 Texas Coast
    28
    Thanks! I didn't post a build thread on BBC but did record to build on a blog. It's in reverse chronological order, but feel free to check it out.
    www.labaronboats.wordpress.com
    Lots of time and care went into this one!
  4. firecat1981
    firecat1981 BBA Counselor
    5,317
    494
    2,288
    Awesome boats! I might build a smaller version in the future. Good luck with the sale.
