1 - 6 of 6 Posts
Up for sale is my 16' Ankona Shadowcast, specs are as follows:
- 2014 Hull - Ice Blue with white Deck
- 2014 Float-on trailer with custom wheels and matching spare - LED Lights
- 2013 Yamaha F20 - Electric start, manual T&T
- Large Rear livewell or can be used for dry storage
- Front bulkhead hatch
- 8 Gallon built in Aluminum Fuel Tank
- Trolling motor pre-wire
- Minnkota quick release puck on bow
- Navigation Lights
- Swing out Cup holder under poling platform
- Stakeout pin bracket built into poling platform
- Yeti tie-downs in center of cockpit spaced for a 35qt Tundra - Will include straps for cooler.
- Automatic bilge pump with manual override switch
- Factory casting and poling platforms, front platform attached with removable eye and pelican hook from Kennedy Tiedown
- Push Pole Holders (Strongarm brand I think? Snag free design)
- Under Gunnel Rod Holders with tubes for (4) rods in rear bulkhead
- Custom Sea-Dek under gunnel pads - Carribean blue over black
- Tibor Push Pole holder on rear platform
- Garmin GPS/Sonar on RAM mount, transducer installed on transom
- Carbon Marine tiller handle extension
- 3 blade stainless prop, aluminum spare
Everything works, garage kept and always cleaned meticulously after/between trips. Lower unit and power head oil change in march 2019. Runs 25-26 MPH with 1 ~200# person, runs 23-24 MPH with two adults and an average fishing load.
No mechanical issues, cosmetically the only issues are (4) bolt holes from where the jack plate was removed (filled with 5200), moderate oyster rash on the bottom, and a scratched area on the transom (see picture).
Call or text: 407-304-7830
Asking: $9600
Discussion Starter · #2 ·
To answer a few questions I have gotten:
- Livewell is plumbed, pump is controlled by a toggle switch
- Push pole is not included but I have a 21' Stiffy Hybrid that could be worked into the sale
- Trolling Motor is not included but I just bought a 45# Motorguide Xi3 that could be worked into the sale.
1 - 6 of 6 Posts
