did you get the foreman prop? If so how’s it do on your cayenne I’ve been wanting to get one for mine
Got out to test the boat this morning. Just a quick overview of how my cayenne is rigged: etec 60 with atlas micro, small-long shawwing, 2 batteries one for trolling motor in bow and one in console, TM, 12 gallon gas tank, micro power pole, and cooler weighing maybe 50 pounds in front of console. Tested with just myself onboard, Im about 160lbs.
WOT is about 32mph give or take, didnt mess around with it that much. The Cayenne is very sensitive to trim so im guessing if i messed around with it more I could squeeze another mph out of the boat. Thats down from 34mph (35 on a good day) with my rogue prop that came from the ankona factory. Cruising at 4500 rpm I saw around 24mph. Although I usually am running it around 5200 if Im being honest... If top end is important to you, this isnt the prop for you.
Take-off: Its a rocket ship now. People talk about how many boat length to get up on plane but idk thats damn hard to judge when you are sitting in the boat. With the JP all the way up and engine in top hole the prop does slip a bit but even when it does itll push you onto plane no problem. Bow lift was significantly reduced and therefore so was the squatting. I didn't try to takeoff in any super shallow stuff so I don't really want to venture to give any numbers on that front right now.
If you don't have a cavitation plate I recommend the shawwing for the Ankona. I've always thought the cayenne was a bit squirly at higher speeds and the plate really makes a noticeable difference in the stability, as well as holding better water pressure. It makes the trim tabs much less of a necessity. Before I got the shawwing I had my tabs fuse blow out on me and didnt have a replacement, it was a brutal run back. Now with the wing I can definitely run without the tabs all the way up no problem. Boat got a tad faster too actually with the wing.
Overall I highly recommend the foreman for the cayenne. Mine is the ultra cupped holeshot xxx whatever you wanna call it version. I'll attach pictures to show how ridiculous the cup is. You could drink out of it.
