I've finally got enough progress to post something. I had debated back and forth about whether or not to post this online, but I figure I learn a lot from seeing other builds and maybe someone will learn from mine. Also, you guys have a tendency to prod enough that progress happens.
I had originally designed the boat to be built stitch and glue, and had completed most of the jig. I was waiting for the right opportunity to go buy the marine plywood (3hr round trip), when I came across some of the conchfish builds on this site. The idea of not having any wood in the boat appealed to me greatly.
I went back and forth about ordering plans and starting over, but I'm the kind of person that would rather build something I designed. So, I took my design from freeship and modified it in sketch-up to include a few design features that Chris Morejohn uses, as well as adding a bit of forward flotation. It took a bit of thought to devise a way to get some use out of the work I had already completed. Screen caps explain the modifications fairly well;I'm not sure why freeship left an artifact of a vagina in the transom, I never bothered to remove it.
My wife scoffed at the $1200 box of foam that arrived on our doorstep. Forgiveness is easier than permission. I had already purchased 3gal of epoxy so I'm stuck with epoxy. Price difference is not that high vs vinylester, but I'm understanding that the work involved is. I'm not sure on lamination schedule yet. I also don't fully understand if stringers are necessary. Maybe Chris Morejohn will chime in.
The boat will land somewhere between 18.5 and 19 feet long. Beam is about 75 inches. Might be too big to be considered a micro-skiff.
I still have to get the transom angle support figured out. I think I will cut the transom out of a piece of foam. I am also going to attach the flange mold to the jig before I attach any foam, but we are going pretty quickly now. The bow mold has a very slight curve in it. I will pull it straight with the flange.
I'm sure work, the 8 month old son, or hunting season will slow me up again. If the temperature doesn't cool off soon, bow season will become boatbuilding season.
Anyway, here comes the pictures.
