flushing honda 30
1494 9
please explain your techniques for flushing.
1 - 10 of 10 Posts
Who Dat
thanks,
Honda says to tape off water inlets if you flush with the ears or the connector. says air can enter the system and cause damage.
wondering is any one has experience with this.
Flush port on the honda is a capped screw in connector.
It's above the water inlets on the lower unit.
Using the flush port without covering the inlets
allows the water to flow downwards and out the inlet covers
instead of being forced up into the block. So, cover the inlets.
page 85 of the owners manual, page 87 of the following linked pdf
http://m.marine.honda.com/pdf/manuals/31ZW2602.pdf
I still prefer the tub method as it's quieter and allows me to verify impeller status.
2008 Gordon Waterman 16' - Zuke 60 Tiller
I slap ears on my Honda 50 and duct tape over the small bottom inlet. Works like a charm and hasn't let me down yet. I don't use the tub method because I usually flush at the marina, campground, etc and can't carry tub with me everywhere I go, where the ears just stay in my boat.
MIKE
Who Dat
MIKE
what happens if you dont tape the inlet?
overheat?
1 - 10 of 10 Posts
