1 - 4 of 4 Posts
Are there more issues, building a glass boat, in the winter vs the summer ?
Curing, mold popping, etc.
Yes, any temp below 65 and you don’t want to be pouring resin. 75-80 is about perfect temp for glassing. When it's cold you are more likely to not set, or if it does it might blush if epoxy.
I've used slow cure epoxy in the 50s. It took days to cure, but it did cure. If you are using poly then things get a little easier. Our shop had summer mixes and winter mixes.
Reactions: fattypoon
I built a Sam Devlin design Duck boat in Port Angeles, WA in the winter in an unheated shop in about 1995 and used System 3 epoxy. I connected two 8 ft 2x4s end to end and hung them from the rafters with ropes & pulleys and mounted 6 heat lamps evenly spaced on them.
I'd lower them to about 6 ft or so (shop had a 14 ft open rafter ceiling) while working on the boat - to keep myself warm, then lower them to 3 or 4 ft (can't remember - it was 25 years ago) and leave them on for the night to keep the epoxy warm while it cured.
It worked like a charm. I spent some time at 1st checking temps at various heights, so's not to under or overdo it or start a fire.
1 - 4 of 4 Posts
