1 - 3 of 3 Posts
Having annual maintenance done on the Yamaha F70 and found a little fishing line around the prop shaft. Everything looked ok, but there was just a little bit of water in the gear oil (but the color was fine). Should I pressure test the lower unit to make sure all the seals are ok?
Wish'n I was Fish'n!
If you can remove the drain plug without the gear oil running out then the seals are holding. But I would still top it off with gear oil, and check for water before your second trip from now. (Give water time to settle after first trip)
1 - 3 of 3 Posts
