'Finishing' cloth?
Discussion in 'Boat Yard Basics' started by Robtattoo, May 17, 2018.
  1. Robtattoo
    Robtattoo Active Member
    18
    6
    28
    Silly question:
    What would be the recommended cloth to lay over 1708 to get a nice, smooth finish or is it just a case of fair & sand, fair & sand, fair & sand?
  2. firecat1981
    firecat1981 BBA Counselor
    5,454
    610
    2,318
    You can either use peel ply to try and smooth out the finish to limit fairing. Or you can top it with some 6oz cloth which would require a bit of fairing, but not to bad.
  3. Robtattoo
    18
    6
    28
    Sorry to be a complete nerk....but what is 'peel ply'?
    Sorry, I'm utterly new to glass work. This gheenoe rebuild/reconfigure is the first time I've ever worked with fiberglass.
  4. firecat1981
    5,454
    610
    2,318
    It's a type of plastic like cloth that you apply over the wet glass. Then roll out at the bubbles. Once cured you peel it off leaving a much smoother surface under it.
    Robtattoo likes this.
  5. Robtattoo
    18
    6
    28
  6. DuckNut
    DuckNut Brandon, FL
    4,803
    636
    1,968
    Put a couple layers of light csm and then the 6oz and it will be smooth enough.
    Since you are being anal :) mix up some phenolic/glass beads to the consistency of syrup and you can do a hot coat.
    Remember that any resin put on without the benefit of glass is susceptible to cracking.
    Boatbrains and Robtattoo like this.
