etec 75 set up and prop questions
3671 15
so i got my new motor friday (YEA!!!) ive got a few loaner props from friends and the dealer
right now im running a 14x17p aluminum and it seems to give the best rpm out of all the props ive run so far HOWEVER at 4900 WOT rpm im still a couple hundred rpms too low, reccomended WOT rpm is 5250
#1 will i gain or loose RPM going from aluminum to stainless ??
#2 how many rpms will i gain going down in diameter 1"?
#3 ive ordered a 13x15p four blade rogue do you guys think im gonna be where i need to be with this engine?
#4 how can i tell if ive got my jackplate up too high or if i need to go up a hole to lift the motor higher?
#5 ive got trim tabs also, how should i run those when running at WOT all the way up ? straight out the back ? down a bit?
1 - 16 of 16 Posts
· > PRO STAFF <
Cheesy is the right word... ;D
Stainless allows for thinner blades, less friction = more rpm's
About 200 rpm change per inch of pitch change
Only on water testing will tell.
If you're pushing air you're too high. If water pressure to the powerhead drops you're too high.
For best speed you want to have the tabs up as high as possible without porpoising.
Adjust down to fit sea conditions and to balance uneven hull loading.
· I Love microskiff.com!
firstly THANKS BRETT!!!!
yeah i was confused because my dealer said id turn less going to stainless because the aluminum flexes more -made sense to me but so does the thinner blade thing so???
#2 was will i change rpm by changing diameter? - i got the pitch thing figured
· > PRO STAFF <
All I've ever seen was pitch change to rpm change.
Diameter change was all about tip speed and wetted surface.
Diameter being limited by anti-ventilation plate to shaft dimensions and engine horsepower.
Reading suggests only a change of 50 to 75 rpm due to diameter change.
alright cool good to know
they make props from 12- 14" in diameter and the gearcase can swing up to a 14 1/2" diameter prop
im looking at a viper if the rogue doesnt work out i can swap tit for tat anyone on here running one?
i tried a 19 viper but it was WAY too big
man ive been prop testing the past month and a half even far as going out on a thursday or tuesday after work and testing at night lol, i bought a BRP prop and going thru the demo props, so far on my set up (16ft flats with a 115hp evinrude) the best results was a viper 13 7/8dia with 21 pitch got the boat to 50-51mph timmed wot 6k rpm BUT the holeshot is horrible, i just got a 4blade rogue 15 pitch they gave to me to demo but it was useless 6k rpm at half throttle 36mph triimed all the way down im kinda stuck now also because they dont have any more 4 blade demos because other people have them and dont return them, im so fustrated with all this prop crap
lol yea i feel you, my dealer sent my new one to the wrong adress yesterday ... good news its going to my moms bad news i gotta pay to ship it back to savannah .... sux
id try a bigger rogue though Ozzy theyre sposed to be the shizz especially for a flats boat theres some guys on here that have em and depending on local might be willing to lend you one for a test spin .... ill let you know how mine works out though if i ever get it ....
as for the outta stock props you might wanna put the call into BRP's customer service and put a bug in their ear about said dealer .... ESPECIALLY if hes a "BRP DEMO prop dealer" ... thats bs and you and i know it if hes a demo prop dealer hes gotta keep EVERY prop BRP make IN STOCK at ALL TIMES ... that or hes a moron and just goes around all willy nilly loaning out props without getting at least a copy of a drivers license or something at 600 bux nearly a pop id have the cops at those guys doors telling em whats what and they had 24 hours to return em or find themselves in an 8'X 8' ya know?
the way this dealer works is you have to buy the prop... and then they give you the demos untill you find the right one..... and yea im probably going to have to go with the rogue 19 or 21, and I didnt think about calling brp diret...maybe they can send them a demo prop for me
Discussion Starter · #10 ·
yea some of those demo dealers dont like to keep everything theyre sposed to have on hand .... i understand its ALOT of overhead but thats the way its sposed to work....
as for a correct prop im thinking a 17 rogue is gonna be your critter.... 19 or 21 will be too big even for a 115 and like i was saying you wanna prop to the high side unloaded so that when your loaded down your still on the high side of the operating range
· Cert. Yamaha technician
Didnt know sundance made a v hull. Its a cool looking design.
On another note, now it all makes sense...
You mentioned you know ken.
Now that you put up a picture of yourself i recognize you.
Your Fidanzas buddie. Remember that night you guys were putting a water pump on his van, and some ass hole in a black mustang came to help? That was me :eek:
Discussion Starter · #12 ·
oh ok yeah now i remember you....
yea its a nice boat it one of their earlier designs the hulls a 1996 model its got a pad on the bottom of the hull too so far with a 17p aluminum weve got it up to 34.5 mph loaded with three people and a 100 lb cooler burning 7.66 gph @ 4900 rpm - im loving the Icommand gauge
new prop is on its way and should be here tuesday and a wet test will follow
anyone know how high the engine should be with 8 inches of setback??
· > PRO STAFF <
The vertical reference points are the underside of the anti-ventilation plate
and the bottom edge of the transom. Based on a 5° hull running angle,
the starting point for fine tuning works out to about 1 inch of lift for 12 inches of setback.
That horizontal distance is measured from the bottom edge of the transom
to the centerline of the water inlet.
Discussion Starter · #14 ·
ok cool brett i was looking friday while we were running WOT and the cav plate was not visible with the jackplate all the way up so im guessing i need to come up higher on the motor? im already about 2 inches above the keel with the jackplate up all the way.... seems like it wants to get squirrley though so?
· > PRO STAFF <
Had to understand this too a while back...
http://www.microskiff.com/cgi-bin/yabb2/YaBB.pl?num=1235777190
Control is critical! If you feel unsafe, drop back down a little.
Looking at the picture you posted, part of the problem may be how far the engine is tucked in.
Trim out until the propshaft is parallel with the line of the keel.
Discussion Starter · #16 ·
yeah i do that ... but when im trailering it the new etecs dont have a travel lock so i jack the jackplate all the way up and trim the motor all the way down - saves the seals in the hydraulics...
read that thread pretty informative but my boat tends to run bow down due the the upward angle of the pad seems like the more weight i put forward the faster she goes.... that day i had three 200lb guys sitting on the back of the casting platform and i was at the helm running 32mph with 2 100 lb coolers, one behind the console seat and one in front of the console seat took it out friday and with my two buddies standing next to the console shed only go 30 .... damn things seems to be weight placement sensitive as hell - i know its got more top end somewhere
1 - 16 of 16 Posts
