I’m planning on covering the bottom of the hull of my Gheenoe with an epoxy & graphite mix. A lot of folks on the various Gheenoe sites and forums that I read like to use Fasco’s Steelflex Superslick 2000. I’m intrigued by the Superslick, and at the same time, a bit leery of it. Superslick contains graphite, but it also contains Teflon, which can be some dangerous stuff. My understanding is that if you burn Teflon, the vapors are lethal ….. I’m wondering if the same type of danger might exist if/whenever you grind the stuff.
Does anyone here have first-hand experience with epoxy & graphite vs. Superslick 2000? Fasco also makes regular Steelfex, which has no Teflon; is this stuff any different from a DIY epoxy & graphite mix?
