1 - 20 of 24 Posts
I got the wiring issue fixed on the boat so I went fishing this morning. Or attempted to. Put the boat in, started fine. Proceeded to the bridge appx 1/2 mile away to get bait. She ran beautiful all the way there. Put it in neutral threw the net twice and got bait. Took 10 minutes. Started heading back to the inlet and at 4000 rpms it seemed to wash out. The engine just revved up and it wouldnt go over 15mph. Idles fine in gear and neutral.
Any ideas as to what would cause this.??
Needless to say I didnt fish, idled back to the ramp and took her home washed her off and flushed the engine.
GOT FEESH?
If it is going into safe mode, shouldn't there be a buzzer or light involved? and I thought safe mode only allows sub 2000rpm to limp back on? I'm just a laymen that has been involved in some safe mode situations with different outboards over the years, So i could be wrong.
Keep us posted though
Ok so you didn't change the motor height ever, But what did you change? Did you move weight foward? where is your livewell and does this only happen after it is filled? did you change the trim angle, or try different trim angles?
Discussion Starter · #12 ·
Have not changed a thing. been fishing a number of times. All the same scenerio each time. Same weight, everything.
I have three props, the engine washes out at the same RPM with all.
I have not had a chance to get by the boat since the issue, but I need to chaeck the fluid level first. Also going to call the mechanic tonight and see what he says.
if you've swapped out 3 props and she's still doing the same thing it would be safe i think to rule those out :-/
Discussion Starter · #15 ·
When you say "washes out",
do you mean that she won't rev any higher than 4000 rpm under load?
It will rev as high as the engine allows. Just at about 4000 rpm and/or 15mph it will not go any faster. Will continue to rev up as well. Its acting like its not in the water enough anymore.
I checked the oil today is was right at the height of the "check level" screw. And it looks clean. Have not drained it.
I've never run into your problem before,
where it wasn't related to loss of power,
a spun hub, ventilation or a bad prop.
I've had total loss of thrust twice,
once a sheared drive shaft the other
a worn clutch dog. Let us know what your
mechanic diagnoses the problem as.
Discussion Starter · #18 ·
50hp honda 2004
salt & fresh water. But salt on the latest trip.
I am headed to the lake tonight to try it again and see what happens, going to try and call the mechanic while i am testing it so he can hear what is going on. Will go from there,
Is the motor studdering at that point? when I was having blowout I noticed a big difference between fresh and salt water. Were you running a chop, or smooth water? How long have you had the boat?
Discussion Starter · #20 ·
I have had it for 2 months. Put about 10-15 hrs on it. It was 4am. Water was glass, no wind. Nothing was different than any other time i have fished. The day I test drove it i had 4 adults in it and it planed fine. And I always fish SOLO.
Im on my way now to test it at the lake. May take a video and try to upload it.
1 - 20 of 24 Posts
