Electrical help Orlando
Discussion in 'Off Topic' started by skinnywater3, Apr 6, 2010.
  1. skinnywater3
    skinnywater3 Well-Known Member
    756
    11
    393
    Heres the deal, I have a golf cart and both sets of lights just recently failed me.. I need to get them back up and running and I'm no good as far as electrical stuff goes.
    It something simple 99% its a loose wire somewhere I just cant find it.. I only have 1 battery and 2 switches so you guys who wire your skiffs could probally find it in 5 min.
    If anyone wants to help me out I will pay you or put you on some reds in the lagoon. Figured I'd give you guys a chance before I go pay some guy to do a halfazz job.
    Im in West Orange county.. I can take pics of my battery if that would help.
    Thanks..Chad
  2. anytide
    4,352
    735
    1,968
    -fuse ??? -'tide
  3. skinnywater3
    756
    11
    393
    dont think so.. Im to the point that I realized Im going to be paying someone.. so given my forum bros a chance to make some cash.
  4. anytide
    4,352
    735
    1,968
    both sets at same time?
    fuse..no. -do you have power to the SWITCH ?? maybe ... -'tide
  5. mark_gardner
    mark_gardner I Love microskiff.com!
    a simple test light will confirm if its a switch or not, if both lights are out chances are they arent getting juice but once again a simple test light will confirm, check ALL connections and make sure you have a good ground ;) i'm assuming you have already verified whether or not the battery has juice right? :-?
  6. hoser3
    hoser3 Well-Known Member
    169
    First start by checking the fuse. Second take a test light to see if you have power to the switch. If you have no power to the switch trace the main power wire going into the switch back to the battery You may have a bad spot in the wire. Also check the Ground wire going from the lights to the frame of the cart. Most likely it is the main power supply if you have lost both sets.
    Feel free to Pm me
    Mike
  7. Frank_Sebastian
    Frank_Sebastian Well-Known Member
    787
    2
    The first thing I would check is the power getting through the switch. If it is then check the negative connection to the lights. The negative ground path may be the problem.
    Sorry, but did you check the bulbs?
    Best regards,
    Frank_S
  8. skinnywater3
    756
    11
    393
    thanks for the help guys.. I've been trying to figure it out for a while, I've grown too frustrated with it to keep messing with it.
    If anyone is in Otown and wants to make some cash money leme know..!
  9. orlgheenoer
    orlgheenoer Well-Known Member
    bring it to the shop
