EC Fury with 60 Merc
Discussion in 'Prop Shop' started by E-money, May 18, 2017.
  1. E-money
    E-money Well-Known Member
    359
    451
    188
    I am just figuring out how my skiff likes to run. If I jack my motor up to where the cav plate is just above the bottom of the hull, and trim my motor up so that the prop shaft is parallel with the bottom of the hull (maybe slightly more), then I am getting 34 mph at 5300rpm with a 14p 4 blade. I can trim the motor up and jack it down but then I need more tabs, and I still only get 34 mph but at 5600 so the motor is just losing efficiency it seems like. This is with full gas, two guys and gear. I'd like to pick up a little top end if possible. Thinking of trying a 13p, 3 blade. Good idea or bad?
  2. Marsh Pirate
    Marsh Pirate Well-Known Member
    36
    21
    83
    I believe I'd go the other way 15p/3.
    E-money likes this.
  3. mtoddsolomon
    mtoddsolomon Lip Ripper
    1,109
    1,028
    718
    I'm still thinking you should go with the same prop that Steve Ward has on his black fury
Loading...
Similar Threads Forum Date
ISO Mav HPX V 17/18 HB Biscayne/Pro/Waterman ECC Fury/Vantage Microskiffs For Sale Sep 10, 2017
Lostmen & Fury Scooters unique rod/gear storage? General Discussion Aug 26, 2017
2012 East Cape Fury Microskiffs For Sale Aug 24, 2017
East cape fury more goodies!! Bragging Spot Aug 15, 2017
Stage 1 of an East Cape Fury Bragging Spot Aug 8, 2017
