For my trailer at least I can back it down so that the bottom of the bucks just barely touch the water. The hubs are still dry and you can drive the boat keel in between the bunks and give it a little gas. Your buddy or whoever can then attach the winch and winch you up the rest of the way. Sometimes I throttle to roll over the keel roller gently and make it easier to latch the winch too.So educate in me on dry launching??? Do you submerge the trailer to load the boat at the end of the day???
I use a snap shackle, Pricey but it works:
Attach the bottom of the snap shackle to your safety chain with a regular shackle and the spring loaded part goes on your boat under your winch hook. (Yes it must be under as you will not be able to get the winch hook off once it all comes tight).
Once you back the trailer down, you release the winch, boat slides back a foot or so and the safety chain will come tight. Undo your winch hook and with a quick yank on the release clip off pops the shackle and your boat slides right off.
https://www.westmarine.com/buy/ronstan--snap-shackles--P002_060_001_002?recordNum=40
Where on the safety chain do you attach the snap shackle? On the hook part or on the chain?I use a snap shackle, Pricey but it works:
When using this cleat, when do you release the winch hook and the safety chain?
This could be just as good and still SS and not the West Marine 1000% mark
up.
https://www.amazon.com/BQLZR-Stainless-Shackle-Swivel-Hardware/dp/B00RMBKSCK
Neither should get wet. But if you're having to walk in water, get a piece of aluminum diamond plate or a carpeted 2*10 and have it run down just off the center of your trailer that way you can walk up or down your trailer to catch/launch without having to walk around in the mud or water. Just Google images of boat trlr walk plank, and you'll get some ideas.Dry launch. Meaning the trailer doesnt get wet? Or i dont get my feet wet?
I need to add a platform/wallboard like this to mineHere is a Maverick and a Beavertail dry launch trailer as examples.
View attachment 6615 View attachment 6616
