1 - 20 of 53 Posts
· Registered
Anyone have any tricks to launching their skiffs on a steeper ramp. Example I want to take slack off the winch and unlatch the clip to the bow but if too steep as soon as I start loosening the winch line it will want to just wind down until it hits the water and loosens up the tension.
Sometimes I just let it and walk down the trailer and release it or I'll try and pull back on the boat to get the winch line loose to unclip the boat.
Simple and not that big of a deal just pitching it.
· Registered
As black dog displays. But I just wrap the stand half wrap. I also walk up to bow with dock line in hand when I am putting it back on trailer. When I get up on the bow it wants to start sliding back down when I bend over to clip it on. Sometimes I don't need it, but have it ready. Don't over do the bunk lube. To much lube is like a loose p---y. Too much of a good thing.
· I Love microskiff.com!
You can leave it clipped and the tension from the clicker should slow it down and or hold on the the strap as it unwinds so it dosnt go to fast then clip the hook to the back of the trailer.
That's what I do.
· Registered
Ok, I gotta ask a stupid question. Waxing the bunks please explain this
I have owned several boats and am waiting on my new Beavertail to be built and this is the first time I have ever heard of waxing the bunks, obviously I assume it helps with loading/unloading at the ramp but how/what/why would you use to perform this
· Registered
Waxing the bunks helps with less friction between the boat and the carpet. My waxing every once in a while it helps the boat not stick to the bunks in launch is easier in the water while dry launching.
· Mostly Harmless
Thanks, guys.
I assume you just rub it on and the carpeting must be dry?
Nah. Many guys apply the wax like a huge crayon to the bunk carpet after they launch and let the sun melt it in to the bunk carpet all day. Before reloading or after launching doesn't really matter; it is a six of one, half dozen of another situation. I don't think wet or dry is that terribly important either. Once it cooks all day, the wax will soak in and the water will evaporate out. My trailer isn't really set up to dry launch, so I get "close enough" and push it off the trailer while the end of the bunks are still a few inches above the water. I need to work on my trailer so that it works a bit better.
...but, as noted, the wax can make steep ramps interesting.
Nate
· Registered
I use a snap shackle, Pricey but it works:
Attach the bottom of the snap shackle to your safety chain with a regular shackle and the spring loaded part goes on your boat under your winch hook. (Yes it must be under as you will not be able to get the winch hook off once it all comes tight).
Once you back the trailer down, you release the winch, boat slides back a foot or so and the safety chain will come tight. Undo your winch hook and with a quick yank on the release clip off pops the shackle and your boat slides right off.
https://www.westmarine.com/buy/ronstan--snap-shackles--P002_060_001_002?recordNum=40
1 - 20 of 53 Posts
