Is it better to drill the drain hole and then seal it with epoxy and redrill it to fit the plug...
...or would it be better to drill the hole a bit oversize, seal the inner surface with epoxy and then come back later, bed a copper pipe of appropriate interior dimensions in 5200 and flare both ends to prevent shifting?
I was going to use the first plan, but I've seen the second a lot on Bateau.
Nate
Nate
