I don't think it works that way homie. Physics is hard.
Hope you make it back.I will be running it Monday (I hope) and will report back ...
Since the early 80's I believe they have been rated at the prop.In terms of coast guard ratings do they rate that horsepower number at the prop? The flywheel? If it's the prop, what if you put on a jet lower unit? Effectively you're putting less power to the water, does the CG go by that number?
