Dolphin Superskiff 60 Command Thrust
Discussion in 'Prop Shop' started by hawkeye, Oct 24, 2017.
  1. hawkeye
    hawkeye Well-Known Member
    12
    3
    78
    I have an older Superskiff with the 18° deadrise.
    I have a Mercury 60 Command thrust on the way. Where do i start with a prop choice?
    Thanks.
    No Bait / Lures Only likes this.
  2. No Bait / Lures Only
    No Bait / Lures Only I Love microskiff.com!
    706
    85
    403
    The Command Thrust is the commercial version with the lower gear ratio lower unit I think. If it is the lower gear ratio you can turn more pitch and larger diameter than the standard lower unit. Call Prop Gods for a start of your prop decisions. I think Mercury has a boat house bulletin for their motors on different boats and all propeller information is listed. https://www.mercurymarine.com/en/us/performance-tests/outboard/
  3. hawkeye
    12
    3
    78
    Ill give PG a try. No bulletins for a Dolphin ☹️. Thanks for the info. Ill keep you posted.
  4. stalkintail
    stalkintail Well-Known Member
    41
    2
    333
    I run a Backcountry 151 with a Merc 60 Command Thrust. I am running a quicksilver Vengeance 15p. I am spinning it right to 6100 rpm's with a light load. I realize it is not the same hull, but it gives you a idea.
  5. hawkeye
    12
    3
    78
    Thanks for the reply stalkintail. I need to verify my tach is accurate. I tried a Merc Spitfire Aluminum 4 blade prop in 15 pitch. That pitch i achieved 5200 rpm , moderately loaded (myself and passenger, some gear), 29.5 mph. If the tach is accurate im thinking about trying a 12 pitch Spitfire.
    Will I lose overall speed by lowering pitch?
  6. SomaliPirate
    SomaliPirate Well-Known Member
    441
    665
    218
    I second a call to propgods. Ken knows his stuff.
  7. hawkeye
    12
    3
    78
    Called Ken. Very knowledgeable and easy to talk to .
    One of the props he suggested is the Mercury Spirfire. The Spitfire is a 4 blade aluminum.
    Initially tried a 15 pitch. Achieved 5100 Rpms, with an avg load , just under 29 mph.
    Next a 13 pitch Spitfire. 5800 rpms 32 mph. Skiff launches effortlessly out of the hole.
    My 20 year old 2 stroke 60 with the standard gear case gave me a top speed of 34 mph. That prop was a 3 blade stainless but i forgot the pitch.
    Im happy with this prop. Im sure a stainless 3 blade will yield faster speed but for now im satisfied with my performance plus the price is right.
    Side note, VesselView app indicated 8 mpg at 4200 rpms, 23 mph with the 13 P Spitfire.
    Thanks for those that contributed I appreciate it!
    ~Hawkeye
    SomaliPirate likes this.
  8. hawkeye
    12
    3
    78
    Update:
    Standard load (gear, cooler, my dad, full tank, etc.) 30 mph5650 rpms.
    Breezy conditions.
    Boat seems to handle choppy conditions much better now.
    I’ll be looking for a SS in the future.
