Docking
1801 18
So new to boating and a have a cs 198v and under slow speeds is a nightmare to steer like when im docking. Am i just a newb or is this common for this hull design
1 - 19 of 19 Posts
Learn to “spring” into any dock and you’ll have much more control. Take a bow line, cleat it then take a turn around the piling or cleat you’re wanting. With this in place you either move forward or reverse slowly and allow the tether to pull you into the dock.
Lastly, never come at the dock any harder than you want to hit it...
Take a minute and see what the wind and current are doing .....if possible, try to let the wind blow you to the dock and always pull in heading to the current
make the elements work for you not against you
if you have to come in against the wind do what lemaymia stated
launch a boat so the wind will blow it to the dock...keeps the wife from getting wet! There are all kind of "tricks"
1. long dock lines
on a flat bottom boat you can "juice" the throttle to kick the boat a little to slide it in the direction you want BUT be very,very careful..not for the novice
Practice....again learn your boat...takes time...we have all been there...and some times we still are
discretion is the better part of making excuses
This...and lots of practice.
Also rest assured you'll never look as goofy as the guys trying to dock a tunnel tiller skiff with a Foreman prop. My "reverse" is really a marginally effective brake...o_O
Practice practicing. It always practicing. Some days you look like a pro, same dock for decades. And one day you just blow it. Just rememder it’s not a car. The road is actually moving under you. So you must compensate for wind and tide. If tide is going perpendicular to where you tie off, aiming right for where you want to be will end you up into the dock or past it. As Smack said. I too have poor reverse and steering in one direction due to prop. Sponson might be a negative in this case as well.
Up on the east coast they have an annual crab boat docking competition; those guys pull out all the stops and exhibit some amazing boathandling skills. It’s an absolute hoot to watch. I’ll look for the videos and post a link when I get a chance.
1 - 19 of 19 Posts
