I'm not familiar with the area, but I do know a little about trout fishing in general. In late April there should be some topwater activity, caddis, stoneflies and mayflies should be hatching. I would go with a 9ft 4X tapered mono leader, with about 18 inches of 5X or 6X tippet. If you will be getting into larger fish, go up a size or two on leader and tippet. Stay with mono leader and tippet for topwater. If you need to fish subsurface, you can go with fluoro, or just stay with the mono. DRO will be able to tell you what flies to use, but I would have dry flies elkhair caddis, Adams, and Stimulators from size 12 to 18, and nymphs pheasant tails, hares ears, prince in size 14-18. Don't forget wooly buggers, in different sizes and colors. Consider bead heads nymphs and buggers. Two thing to remember
1. Almost everything a trout eats is less than 1/4 inch long and brown
2. Split shot is your friend
This is in no way a comprehensive list of what and how to, but it will get you started. Blessings!!
