I'd be all over it if it had power t&t. I've got the same motor and love it, but I'm getting older and t&t would be handy. Would you part with one of the props separately ?
Discussion Starter #3
The only props I would part with is the SrA 3 blade and the aluminum OEM Prop
Discussion Starter #7
What difference did you notice between the stock prop and the 15" pitch. Is it stainless?
Yes the SRA 3 blade is stainless, the stock prop is aluminum thus flexes in the water and won’t give you the same performance as the stainless because stainless does not flex in the water when running. I saw a significant difference in speed about 5-6 mph more from the 13 aluminum to the 15 stainless
