1 - 20 of 29 Posts
I am thinking about building a back/poling deck flush with the back seat of my canoe. What I am looking for is the best type of materail, lightest and most durable.
Curius to see what everyones thoughts are. Oh, and it will be glassed in and painted no mater what the materal.
Austin
Epoxy resin is known in the marine industry for its incredible toughness and bonding strength.  Quality epoxy resins stick to other materials with 2,000-p.s.i. vs. only 500-p.s.i. for vinylester resins and even less for polyesters.  In areas that must be able to flex and strain WITH the fibers  without micro-fracturing, epoxy resins offer much greater capability. Cured epoxy tends to be very resistant to moisture absorption.  Epoxy resin will bond dissimilar or already-cured materials which makes repair work that is  very reliable and strong.  Epoxy actually bonds to all sorts of fibers very well and also offers excellent results in repair-ability when it is used to bond two different materials together. Initally, epoxy resin is much more difficult to work with and requires additional skill by the technicians who handle it.
Vinylester resins are stronger than polyester resins and cheaper than epoxy resins. Vinylester resins utilize a polyester resin type of cross-linking molecules in the bonding process.  Vinylester is a hybrid form of polyester resin which has been toughened with epoxy molecules within the main moleculer structure.  Vinyester resins offer better resistance to moisture absorption than polyester resins but it's downside is in the use of liquid styrene to thin it out (not good to breath that stuff) and its sensitivity to atmospheric moisture and temperature.  Sometimes it won't cure if the atmospheric conditions are not right.  It also has difficulty in bonding dissimilar and already-cured materials.  It is not unusual for repair patches on vinylester resin canoes to delaminate or peel off.   As vinylester resin ages, it becomes a different resin (due to it's continual curing as it ages) so new vinylester resin sometimes resists bonding to your older canoe, or will bond and then later peel off at a bad time. It is also known that vinylester resins bond very well to fiberglass, but offer a poor bond to kevlar and carbon fibers due to the nature of those two more exotic fibers.  Due to the touchy nature of vinylester resin, careful surface preparation is necessary if reasonable adhesion is desired for any repair work.
Polyester resin is the cheapest resin available in the marine industry and offers the poorest adhesion, has the highest water absorption, highest shrinkage, and high VOC's.  Polyester resin is only compatible with fiberglass fibers and is best suited to building things that are not weight sensitive.  It is also not tough and fractures easily. Polyesters tend to end up with micro-cracks and are tough to re-bond and suffer from osmotic blistering when untreated by an epoxy resin barrier to water.  This is really cheap stuff.
After building the Grass Slipper (see post "Start from Scratch")
I will never use anything but epoxy.
Easy to work with, stronger, waterproof.
About the red fiberglass,
that is the result of using a chopper gun to apply fiberglass.
Not the strongest way to build with fiberglass.
Just faster and less expensive to work with.
see info here:
http://books.google.com/books?id=ileMYXGZ3OQC&pg=PA90&lpg=PA90&dq=red+thread+chopper+gun&source=bl&ots=GyynPZ-ojV&sig=NeJgDaFOmDO060d7ekm_bG2wmMM&hl=en&ei=NoOtSaf8NJ6DtwfPtIX-BQ&sa=X&oi=book_result&resnum=1&ct=result
SkiffShop says: Why not 2 pieces of 1/4" Luan plywood laminated (for a nominal 1/2") with 3mm Sea Dek applied in lieu of the nonskid?
;D  That'd work wouldn't it. Exterior grade luan is less expensive than birch.
Still going to have to seal it either way, and Sea-Dek would look sharp.
Not mat, 6 ounce fiberglass tooling cloth to strengthen and seal the wood.
Mat is a filler materal composed of short fibers. The tooling cloth is stronger.
[smiley=1-thumbsup3.gif]
a lot of times the red you see in resin is a dye the put in the hardener so you can see how hot your mixture is.
That's what I was going to say.
What about using starboard for the decking material? I've seen many people use it on the FS forum.
NOTHING sticks to starboard.. The only product that even claims to somewhat adhere is lifecaulk.. not even 5200.. or epoxy resins
Wow, I had no idea. I had seen a build up of a Carolina Skiff years ago on FS forum where they had said that they made the whole front deck out of starboard and glassed it in. I had no clue what starboard was at the time. Heck, I didn't even know exactly what starboard was until after this thread. I actually looked up on it to see exactly what it is.
Why would you want to glass over starboard anyway? Just cut it to size and you're good to go... It's heavy though.
Starboard is a heavier material given the same relative size as most woods.
Put me down for the laminuated luan idea. In building my boat, I am leaning toward laminated luan wherever feasible (decks, floors, etc) for it's strength to weight ratio. Very cheap too, on sale at Lowe's for $10/sheet right now. Pick a good piece for the stack, one sheet would be plenty.
Epoxy is the way to go if you ask me.
1 - 20 of 29 Posts
