I had a lithium battery with my f70. Relion brand. The f70 didn’t like the voltage spikes and kept shutting off. Even voltage is very important for f70, spikes will cause the motor to shut down.
Please elaborate as i am looking for battery...I have been speaking with the fella at stealth 1 charging systems and he seems to think they are a no issues with a lithium pro on the F70. I will ask him about these voltage spikes.
Just curious, which model battery from Relion. I've been researching what to use on my new skiff that will have the F70 and considered Relion. I'll probably stick with either flooded lead or possibly AGM for now but haven't ruled out lithium.I had a lithium battery with my f70. Relion brand. The f70 didn’t like the voltage spikes and kept shutting off. Even voltage is very important for f70, spikes will cause the motor to shut down.
Do you have a reference to the exact language here? For Suzuki to state as you do that "using a lithium start battery will void your warranty" would actually put them in a position to pretty clearly violate a federal law. I'm not disputing they might have some kind of lithium battery warning language, but I find it highly unlikely that it is as strong as what you posted.Word of caution. Read your owner’s manual for your outboard. Suzuki is very clear that using a lithium start battery will void your warranty. I don’t know about Yamaha but it is worth checking.
I called Suzuki customer service and asked point blank. He said it was a very common question. I think his words were, if there is a problem and it is determined you had a lithium battery, it would void your warranty and not be covered.I'd like to see that. I haven't looked at my manual that closely but I did call Suzuki when my Evo was getting built and I was still considering Li Batteries and they told me they did not void the warranty.
I work with OEM warranties as a primary function of my job as a distinct manager for Subaru. There are a lot of inaccurate statements made like this by dealers and even customer service reps which are often contracted/outsourced for many companies.All my Suzuki manual says is that they do not recommend sealed, agm or gel batteries, guess they only recommend flooded batteries to ensure the charging system will work correctly.
But do not see how any federal law would be violated if they did void the warranty for Li, most Li batteries I have looked at require a dedicated charger.
Void is an inaccurate description of the enforcement. A claim may be denied but the warranty is not void.I called Suzuki customer service and asked point blank. He said it was a very common question. I think his words were, if there is a problem and it is determined you had a lithium battery, it would void your warranty and not be covered.
I’ll look it up in my manual when. I get home in a couple hours.
So my manual (2014) says the same as Bones' manual, "the use of maintenance free, sealed, or gel cell batteries is not recommended because they may not be compatible with Suzuki's charging system." I also looked up the latest edition of the manual for the DF60a, which is the motor going on the new boat, and it says the exact same thing. I guess the CS rep gave me some fake news. Thanks guys for helping me dig out the truth. I guess I'm back to looking at LiFePO starting batteries.All my Suzuki manual says is that they do not recommend sealed, agm or gel batteries, guess they only recommend flooded batteries to ensure the charging system will work correctly.
