1 - 8 of 8 Posts
Easiest way without the proper tools is to, simply to swap the top and bottom coil and see if the spark moves or still has no fire on the bottom. If it stays the same then it's probably the power pack, if the stater was bad you would probably be getting no fire at all. Also check your spark plug 1st; I have had about 30 plugs go bad this year all NGK.
These were the only plugs you had go bad and not a single other brand?
I'm curious because I have some issues with power equipment that I have never had before and all plugs are NGK - which used to be the best. Just trying to figure this out.
1 - 8 of 8 Posts
