28419[/ATTACH]28418[/ATTACH]
28420[/ATTACH]28421[/ATTACH]28422[/ATTACH]28423[/ATTACH28424[/ATTACH]28425[/ATTACH]28330[/ATTACH]28331
Up for sale is our A.F.F.S. Indoor Small Watercraft Pond demo skiff. It has only been used in the Indoor Pond (Outboard used for display only) around the U.S.A. and Canada and never fished. Provided to us on a promotional deal by Pughar Gheen himself. It has only been used for fly casting and spin fishing demonstrations. It is a 2011 model with forward and rear casting platforms. Hull color is light grey with black and white spackle paint job on the cockpit deck. Raised Forward and rear decks are non-skid white. No permanent poling platform has ever been mounted on this boat. Instead, it has a removable turnbuckle mounted casting platform as often found on the forward decks of many larger flats boats. It has the center box/passenger seat hinged that can be used for dry storage, cooler or a live well if plumbed. Box has a drain and plug in the bottom that empties out under the cockpit deck. Also has a slotted stainless water drain
mounted into the cockpit deck in front of the passenger seat. Has 4 horizontal factory rod holders that can hold 2 9' fly rod outfits on each side with fly rod tip PVC tube protectors mounted under the forward deck. Has factory mounted pole holder with a Super Stick telescopic push pole included. The under decks storage areas have custom made black canvas snap-on covers. Forward storage holds a 3 gallon fuel tank with fuel hose mounted under the cockpit deck to the stern and ported out next to the motor. Has Mercury/Yamaha connector on the motor end of the fuel hose. Factory installed bilge pump with stainless thru hull with cockpit switch. Room under forward deck for a second removable tank. There is a factory model stainless fixed jack plate on the transom. At the present time, it has a brand new 2002 Mercury 15 H.P. 4 stroke electric start outboard with less than 1 hour run time on this motor. Fully documented by the dealer that provided the outboard for the demos. The motor is short shaft set up for steering wheel or a stick steering system install. Comes with a new side mount factory Mercury gear shifter with trim/tilt switch and cables that have never been hooked up to the outboard. The skiff is currently sitting on an A.F.F.S. custom 2011 Karavan galvanized bunk trailer with no miles on it. Transported to events inside our custom show trailer not towed. The custom A.F.F.S. aluminum racks mounted to a trailer allow for the additional transport of kayaks, SUPS or rafts above the skiff on 1 trailer. has LED submersible lights and mounts for night launch lighting. Skiff is available with or without the trailer or the outboard. Just needs to be finished rigged to the new owners taste. Paperwork for everything.
Custom Gheenoe NMZ Skiff @ $3,000
Mercury Outboard with shift box @ $2,000
Karavan Trailer @ $900
Custom trailer rack @ $1,000
Purchase entire rig @ $6,200 or B.O. close to it
Contact Capt. Mike @ 732-267-0058 Boat is in North Fort Myers, FL. ready to go
