SOLD/EXPIRED Custom Gheenoe Lowtide 15 w/25hp Yamaha
Discussion in 'Sold/Expired Classifieds' started by Dustin1, Oct 31, 2014.
  1. Dustin1
    Dustin1 Well-Known Member
    56
    29
    693
    2007 Custom Gheenoe Lowtide 15
    This boat was one of the first Lowtide 15’s built, and one of the very few that is coast guard rated for a 25hp engine.  This is a very capable, well-rigged, and well-maintained skiff that can pole in the skinny with the best of them, but also has the range and handling capability for more open water fishing.  This boat has fished from the marshes of South Georgia to Flamingo and all points in between.  I have taken it to the Shark River and points north out of Flamingo on many occasions. The features:
    • 2007 Lowtide 15, all white hull, 15' 10" length
    • Continental galvanized trailer w/spare tire
    • Raised casting decks (light gray colored) fore and aft, under-deck storage
    • 2007 25hp Yamaha 2-stroke (half the weight of the four stroke)
    • 11 gallon built-in aluminum fuel cell in the bow with electronic sending unit
    • CMC hydraulic jack plate with controls wired into Yamaha binnacle
    • Custom aluminum riser plate for outboard
    • Bob’s Machine Shop stabilizer plate
    • Power-tech 4-blade Stainless Prop
    • Custom fiber-glass trolling motor adapter mounting plate on bow
    • 55lb Minnkota Riptide hand-control trolling motor
    • Minnkota quick release mount
    • Keel guard
    • Fore and aft built-in rod tubes (can accommodate 9’ fly rods)
    • Custom horizontal rod holders port and starboard
    • Center console
    • Stainless steering wheel with tilt steering
    • Eagle depth finder
    • Ram ball mount for handheld GPS
    • Garmin power plug for handheld GPS
    • Console-mount navigation lights
    • Cabelas AGM Battery
    • Triple vertical rod holder on console
    • 50A fuse block in console for trolling motor
    • 12 V/GND bus bar in console
    • New 5-switch panel with 12V outlet
    • Twin 1100 GPH bilge pumps with console mount controls
    • Analog fuel gauge w/light
    • 2-bank (10A each) onboard charger
    • AC bulkhead plug on console for charger
    • Poling platform
    • Poling platform mounted removable stern light
    • 20’ Stiffy Hybrid Push Pole
    • Stiffy push pole holders starboard with bungy cord retainers
    • Fuel-water separator (new 2013)
    • Trailer guide posts
    • New tires, bearings, grease seals (2013)
    • LED tail lights
    The shallow water performance of the boat is outstanding with the combination of the jack plate, the four-blade prop, and the stabilizer plate (which funnels water to the prop when the motor is at high running altitudes).  It will run extremely skinny if the need presents itself.  I have seen 29 mph light and typically in the 25 mph range with a very full fishing load and two big guys.  You could definitely get more with a 3-blade prop if that was your interest.  The boat likes to run with the jack-plate up high and will maintain a plane with good speed at the highest position when a rock bar jumps out in front of you unexpectedly.  Typical fuel economy with a full fishing load is around 9 mpg, giving you a good 100 mile range.
    This boat is turn-key, ready to fish.  The boat is located on north Merritt Island.  Please call or text Dustin at 904-708-0689 or email at flashes15@yahoo.com.
    Price:  $8500
    Pictures:
  2. steve77777
    steve77777 I Love microskiff.com!
    102
    1
    93
    perfection Gheenoe!!
  3. Dustin1
    56
    29
    693
