1 - 3 of 3 Posts
Located in Jacksonville, Florida
I purchased this boat, motor and trailer in March of this year. The only items that I purchased used were the motor and fuel tank. Everything else I purchased new.
2007 9.9 Mercury Four Stroke - Pull start. Manufacture date is July 2007. I just had this motor tuned up (May 09): carb cleaned, water pump replaced, fuel filter replaced, motor oil changed, lower unit oil changed, spark plugs replaced and corrosion block sprayed on motor (inside of cover). This motor has been used in salt water but flushed every time. Motor runs perfect. I will include the flushing muffs in sale.
2008 Lowe 1436L Jon boat -
* 40lb thrust Minn Kota Trolling motor mounted on bow
* Front casting deck platform (3/4 plywood treated with Thompsons water seal)
* Floor (3/4 plywood treated with Thompsons water seal)
* Two swivel padded seats (removable)
* Humminbird PiranhaMax Depth/Fish finder
* Bilge pump
* 15 lb Mushroom Anchor
* Red/Green Bow lights, White Stern light
* Switch box controlling lights, bilge pump and power to depth/fish finder. Each switch connected to fuse panel in box for power protection.
* Fire Extinguisher
* 4 Swiveling, adjustable rod holders
* Vertical rod holder (holds 3 rods)
* EverStart Marine Deep cycle battery
* Transom saver
* 3 gallon fuel tank with in-line fuel filter
* 2 life vests, 1 seat cushion that also is an approved flotation device
* Emergency Paddle and whistle
* 3 cup holders
2009 Continental Trailer -
* Guide on bunkers
* PVC guide ons with trailer lights mounted at top of PVC
* Accepts 1 7/8 ball
$3,900  Sold as a package only, will not break up. I am not looking to trade, for sale only.
1 - 3 of 3 Posts
