Cup holders in console, any suggestions?
6.1K views 32 replies 25 participants last post by  whaler76
A little tip for using the hole saw.
Pre drill your center hole with the pilot bit WITHOUT the hole saw installed, then install the hole saw on the arbor and start out drilling in reverse until you are through the Gelcoat (the top colored part), then switch to forward to continue drilling and finish the hole.
This helps to resist chipping especially on older Gelcoat.
