1 - 1 of 1 Posts
After what seems like an eternity, I have finally finished the Crystal 16 Flats Skiff! The delays were caused by some paying customers as well as my ongoing battle with cancer. I won't make the mistake of announcing a new design before it is finished again!
The baby brother to the Osprey 18, the Crystal 16 is very similar while being completely different! The only thing they share is the 66" beam, everything else is different.
She has a casting deck forward and two casting decks outboard back aft. Her fuel tank is a simple portable unit that is easily purchased and installed between the aft casting decks. Tiller steering only, no console! All her batteries will be up forward under the casting deck.
Her construction is 1/4" canoe strips with a layer of 1208 double-bias fiberglass set in epoxy on either side. Framing is all 12mm marine plywood, glued in with epoxy fillets and 1208 tape. I think she will be a fun boat to build and fish! Just remember to keep her simple and light!
Her specs are as follows:
LOA: 15'-9"
LWL: 14'-2"
Beam: 66"
Draft (Keel): 6"
Displacement: 1,100 Lbs
Fuel Capacity: 6.5 gals.
Deadrise: 6 Degrees
Freeboard (Fwd): 18 1/2"
Freeboard (Aft): 13 1/2"
Power: 25-30 HP Tiller OB
Speed: 27 Knots w/25 HP (Estimated)
Construction: Strip Planked Composite
Smith Marine Design
Contact/Designer: Timm Smith
9200 N. Lennox Terrace
Citrus Springs, FL 34434
352-465-3123
www.smithmarinedesign.com
As I don't want to open myself up to any more spam, head over to my contact page at my website for my email address!
1 - 1 of 1 Posts
