Just spent the morning wiring the new boat. Is there some type of corrosion protectant that I should use on my buss bar connections and such?
a good habit to get into is using a liquid neoprene - liquid electric tape - before running the screws in - coat the screw ,after it's in the loop connector,with the liquid,then thread the screw into the buss bar,coat the barr in the same liquid,after all the connectors are installed - doing this,the screws will not vibrate loose,they will easily come off,when turned with a screwdriver,and the buss is covered in a waterproof barrier...
lear research corrosion block products are,in my opinion,the best products on the market for corrosion resistance...
http://www.learchem.com/products/corrosion-block.html
