So I have been working on a small Tri Hull Skiff. I have replace the transom using coosa (Laminated 1/2" to make motor area about 1 1/2"). I am looking to start laying out the floors and decks. I like the coosa because its almost just like plywood. I can get 1/2" coosa for about 165 a sheet the Divinycel is about 125 a sheet. I am trying to make the boat light and fast. what should I use? With the divinycel what do I do with exposed edges such as bulk head cut outs and hatch openings? Can they simply be covered with epoxy or do they need to be glassed? I know it needs to glassed on both sides but if I cut an opening what do I do? Which is better
