Converting a canoe to a flat stern.
8729 6
Hello,
I recently acquired an old fiberglass canoe. I would like to convert it to a flat stern to put a small mud motor on. I'm hoping to use it as a small duck boat. any advice on how this could be done would be greatly appreciated.
· Registered
I have made several mounts ...very easy to do no need to cut up or modify your boat ...
I will try to get some photos up soon ...
· I Love microskiff.com!
You might find http://www.boatdesign.net/forums/diy-marinizing/weed-eater-engine-conversion-1681.html interesting. There is a lot about small mud motors to be found and they are mounted on different types of hulls.
· Mostly Harmless
This boat is the best canoe-to-boat build I've seen.  He did a hellacious job.  I swear the original build thread was on here somewhere, but I only can find the threads that Snooker posted after he bought it.  I am probably thinking of another canoe-to-boat project
http://www.microskiff.com/cgi-bin/yabb2/YaBB.pl?num=1199391255/0
http://www.microskiff.com/cgi-bin/yabb2/YaBB.pl?num=1200436703
http://www.microskiff.com/cgi-bin/yabb2/YaBB.pl?num=1210001780
It isn't a terribly difficult project.  Obviously, the one that is linked started as a flatback canoe and ended up a bit higher class than a quick and dirty duckboat build needs to be, but you can infer how the builder worked though the build as you look through the pics.  The process for a changing a double ender to a flat back will require a bit more thought, but it will follow the same general concepts. You'll probably lose 10-12" of length.
Nate
· Light, Strong, Cheap. Pick Two.
Canoes are not plaining hulls.  They have a hull speed just like sail boats.  They become very unstable if you try to exceed them.  Try towing one behind your boat and watch what happens. ;)
Gheenoes on the other hand dont have any stern rocker and are safe to operate at plaining speeds.
· I Love Skinny Water
I can't imagine putting a motor other than an electric on my fiberglass canoe. No way to stand in it. Talk about tippy
