Conchfish 16
190897 Views 742 Replies 76 Participants Last post by  commtrd
2
Since everyone doesn’t have IG or not a member of Bateau.com, I will doing a build thread here. I started today build a strong back and was also able to cut some mold frames out. Here’s is the progress so far.
Floor Sport venue Flooring Drawing
Wood Floor Plywood Hardwood Lighting
See less See more
Reactions: 5
121 - 140 of 743 Posts
@Travis Smith looking so good!!
1. When did you remove the screws holding the foam to the frames? Before the skim coat of thickened epoxy? And if so, when you removed the screws how did the foam stay in place, just the gorilla glue??
2. How did you radius your corners at the chines, etc in preparation to the cloth? Did you use a router or just sanded by hand?
I think he plans on just pulling the screws through the core and then filling the holes afterwords.
I removed all the screws after the gorilla glue dried. It stayed in place fine. I used a belt sander and I hit all the edges. And now that I am almost done with fairing, I sharpen the edges.
Reactions: 2
Man you are killing it! What layup are you going with on the inside? By choosing epoxy over other resins. Saves you from using CSM. But did you contiplate a outer layer of CSM for sanding/fairing?
Thanks man!! I will be running three to four layers inside too. I will be running some 12 oz biaxial for the transom. I have now decided to run a 50 probably. And full deck as the majority of people say a Whipray rides better heavy.
Reactions: 2
Haven't seen any updates. The way your going your probably out fishing on it.
Reactions: 3
I’m not quite sure what you’re considering lofting. Sorry for my stupidity. Maybe someone else can chime in.
The weather here north Florida has been crazy lately. I haven’t messed with the boat in a while. I have probably 6”s if standing water in my back yard. It has rain everyday and is really humid. I was able to put on a little fairing today. It’s almost ready for primer.
Lofting is just expanding the planned lines to full size.
JC
Basically, how did you build ur forms? Did it come with full size patterns to trace, or did you get measurements to make them.
Thanks.
Reactions: 1
Thanks.
You lay out measurements basically connect dot to dot
Reactions: 1
JC
What Chris typically sells are scaled drawings. 1.5”=1ft you then draw out to full size and connect the dots. Or use a cad software and plot the work points then take that to a cabinet shop to have the stations cut out on a cnc table.
Reactions: 1
Wow, Travis you are moving right along. I’am amazed you are taking the time to answer all these questions.
Let me say to you all that Travis is doing an excellent job. He’s getting it done quickly because he’s just working on it instead of just dreaming about building one.
There are lots of ways to build Skiffs like this using epoxy or just plain ole cheap as you can buy polyester resin.
Epoxy is great because it does not smell like polyester resin and it can have a slower working time.
Rick Hambric is miss leading you all with the info that you can put polyester resin, on top of epoxy. NEVER SHALL THE TWO RESINS EVERY MEET! Don’t ever do this. The other printed stuff he showed is just a copy of my emails to him answering a shitload of questions just like yobata.
And after all the time spent still no Skiff to show for it. Geeze come on and just get out in the shop and start on something.
The cloth layups can be just like I show on the plans. I don’t like 1708 and all the tri axels because you get lots of little air bubbles in the weave and they are to me not as strong as a good 10 oz. cloth layup. Try laying up a one off like Travis showed with the cloth in 1708. A nightmare and a whole lot more resin.
I will give a cautionary note here, all people that sell fiberglass supplies are salesman. They want to sell you stuff. Be careful as they are not going to build the Skiff, you are. Look at the plans. Listen to the guy who designed the Skiff. His name is on the line not the salesman’s.
Now as to my plans. Yea they are old school plans. That means they are like all the others from the past 150 years. What you get is numbers that you have to layout on your own using your brain, your hand and a pencil. It takes 6th grade math, English knowledge, to draw up the stations. Having cad patterns takes all the fun out of actually learning the process of figuring out the treasure map that is called a set of plans.
I am very happy to see a guy like Travis getting it done. There are a dozen people building to this design right now along with a whole bunch more building to my other designs up to 37’. All it takes is just basic skills with the mind set that it’s just one day and step at a time. Yes and some $ to buy the materials. Sites like this can give great inspiration and shared knowledge. But beware, some guys have never had glue on their hands but will quote you the gospel according to them.
One last note here, traditionally when buying a set of plans you are purchasing the right to build one vessel from those plans. Any more and you have to pay the designer another plans fee again for each vessel built.
I have not written this on my plans as I want to see a fleet of these skiffs out there instead of a few extra $.
On my blog site....hogfishdesign.wordpress.com You can see most all my designs and I feel most anyone can find a way to download them and get your own info there for FREE. I have posted all this stuff to hopefully inspire others to get going and design and build their own boats. Remember, what I say is just an opinion based on my past work and experiences. Does not mean it’s the way to go. Lots of ways to build a skiff.
See less See more
Reactions: 5
What Chris typically sells are so-called drawings. 1.5”=1ft you then draw out to full size and connect the dots. Or use a cad software and plot the work points then take that to a cabinet shop to have the stations cut out on a cnc table.
Scaled not so called. Just re read my post and realized I was autocorrected damnit! @Chris Morejohn , I have been slowly putting the prices together. I buried my mother today and all things in my life have taken a backseat for the past month. I’ll be in touch sir.
Reactions: 2
Rick, sorry to hear about your Mother. I dread that day in my life.
Reactions: 1
Rick, my mom passed away 4 months ago, my condolences and I feel your loss. I was only correcting you on the epoxy thing. Trust me nothing will stick to epoxy other than epoxy if prepaided properly.
Otherwise, you know you want to do it. Just do it. You already have enough info. Get going, it only starts with a jig and then some stations, a then...... best of everything my friend
Reactions: 3
Travis, didn’t mean to derail... back to your awesome conchfish!!!!!!
I wondered about this. They’re not always clear, but there’s enough information on some of these drawings to easily reverse-engineer your own skiff from. Glad to see that’s by design.
But that said, there’s nothing like having your own copy of the plans framed on the wall while your skiff is out on the water.
Reactions: 2
2
Skiff Automotive exterior Tent Vehicle Dinghy
Asphalt Road Lane Transport Road surface
@chrismorejohn
Wow, thanks Chris for all the kind words. I will always take time to respond to questions. I am always willing to help anyone with anything I can. As Chris said take it one day at a time. Due to rain in north Florida, I haven’t got much done in the past month. But now that the weather is a little better each day I take 30 minutes to an hour and sand. The sanding can be a PItA. But do a little at a time to not get burned out. The fairing is almost done. I am currently building the chines up.
I am using pvc trim board screwed into the side of the boat. Then I mix thickened wood flour epoxy to build the chine.
See less See more
Reactions: 5
I get excited whenever I see this is a new post -- thanks for sharing everything you've been doing with us. I think that sometime in the next year I'm going to start a build, and it very well might be this boat built in a very similar manner (foam and epoxy), so this is very helpful.
Thanks again, and keep up the good work!
Reactions: 3
