701 - 720 of 743 Posts
· Registered
Just read all 36 pages and all I can say is wow.
@Travis Smith , were you happy with the height you built your strong back? If I attempt this, I may look at welding a steel frame with big casters so I can roll it outside in good weather. I could also make it where the height is adjustable and if I got really high tech, I could make it tilt. That would save a LOT of bending over.
· I Love microskiff.com!
You could build a strong back onto a boat trailer. It would require less material and the trailer frame is already square and true so you could temporarily bolt some long 2x6’s, a few cross members, and then your molds. You can roll it out on the drive way to work and roll it back in. When it’s time to flip, bolt the bunks, etc back on. No need to build a cradle.
· Registered
The good thing about building the cradle is you can turn it into a table to build your deck.
· Registered
Yeah, I'm going to just build an all wood strongback. And like you said, I can take my stations off and lay down door skins or whatever I come up with to do my cap on. I do want to put it all on wheels though so I don't have to fill my garage and everything in it up with dust when I do my fairing etc
· Registered
Man, if I knew the first thing about any of this, I'd build one too. Such an attractive hull. Sublime, you're just down the road from me, would love to see yours when you finish!
You’re welcome to see the process anytime after I get started.
· Registered
The name escapes me but there is this particle board covered in smooth white skin at Home Depot and Lowe’s that I have been using that as long as you keep it dry is the best. Just wax it well and tape the joints. Get at me on IG if you need anything.
mantisinshore
· Lip Ripper
mantisinshore
ive been following closely, your build is looking amazing! The seams between the foam is incredible!
· Registered
Melamine. You can do one better by sanding it perfectly smooth with a d/a and 320 grit then wax or pva
mantisinshore
