I am going to step in here with a bit of details to ponder. I do this to just add my opinion to a (Microskiff) site.
I am not in here now to try and sell this design, just to give my thoughts on the practicality of 12’-14’ Microskiff designs.
The photos I share are from 30-32 years ago with my wife Rachel and our first daughter Kalessin using our 12’3” earlier version of the current designs. We are in the Bahamas, USVI and at sea in the Atlantic.
The pink hull is solid glass the rest 1/2” core. It weighed 140lbs.
The other hulls were core with the 12 versions I built weighing from 115-180 lbs depending on the interior.
I could hoist these skiffs on deck using a simple block and tackle. I used my main sheet on the min halyard. Was very easy to stow aboard.
These skiffs plus later versions made many Gulf Stream crossingbeing towed behind our sailboats in all kinds of seas up to 8’. We regularly towed between all the islands in the Caribbean with 30-60 mile open ocean sea conditions and trade winds of 20-30 knts.
They never gave any trouble ever. The only water that was ever inside after a passage was from a passing rain squall.
These small designs are very seaworthy.
I would not ever tow a Jon boat, Geenoe type, open canoe, rubber dinghy and most standard small skiff hulls for each of their faults in chop / seas over 2-3’.
The next thing to ponder is that these Micro Skiff hulls only need a 10-25 hp to push along quite well. These engines can be taken off with ease and stored away safely.
A 14’ skiff that weighs from 180-225 lbs is easy to store on its side along side a fence or building.
These skiffs do not need a battery, trim tabs, bilge pump, electrical components built in fuel tank, Purple lights, etc.
OR they can have it all, well the 14’ version, would hate to see a 12’ hull full of stuff.
The choices of materials can be strip planked wood of any soft easy enough to bend planks,
Or scrimmed balsa core, Nida core, any core from 1/2” to 3/4”.
My current version I built 8 years ago buying all materials retail which cost $1,500.00 to build.
Today it will be more.
You will need 12-15 gal resin.
Glass bubbles ,about 5 gal bucket worth.
Paint,
PVC for rub rails,
Eglass cloth and 1-1/2 Oz matt.
You make a trim plate to bolt onto the outboards cavitation plate to use as your trim tab.
I like plastic cleats to tie beach finds down with.
I have never needed a flats skiff because I could fish any where with my12’3” skiffs.
We raised our babies in them they were so safe and seaworthy, dry and stable.
For the 14’ design I would make the tower removable with 2 sockets glassed in the stern to slide the tower legs into.
Terry Baird in Hawaii is building the 14 to fish his flats at night in pursuit of world record bonefish.
Think out side of the box ….er hull. Don’t be conformist, just think of being able to cross any bay with a 15 hp, two people, draft 4-5” and either pole, paddle, row around burning 1-1/2 gals of fuel.
