Looking at an older boat rigged with a Yamaha Pro-V 175. Hull and motor are '96 but have only a little over 400 hours.
Does anyone know what the compression #'s should be for a motor like this? I am buying this boat from a reputable source and they've emailed me compression #'s at 110lbs and even.
Naturally I will check them myself on Monday when I get there, and normally I see #'s in the 110-130lb range.
So the #110 has me a bit concerned, and I know there can be some difference from one gauge to another but 20lbs???
Is this a normal compression figure for a motor like this?
