AR-style look and is modeled after the original Colt M4. A "Tactical Rimfire" rifle, the M4 Ops is an upgraded version of the .22 M4 Carbine. Instead of the standard forearm found on the carbine, the Ops has an RIS, or Rail Interface System, that provides tactical railing on four sides allowing for you to mount a variety of available accessories. Specifications: * Item No.: 2245051 * Caliber: .22 L.R. * Capacity: 30-round Detachable Magazine * Mode of Fire: Semi-Auto * Barrel Length: 16.2 in (412 mm) * Barrel Twist: 1 in 13-3/4 in * Rifling Grooves: 6 * Rifling Length: 13.78 in (350 mm) * Front Sight: Adjustable - Elevation * Rear Sight: Adjustable - Windage & Elevation * Overall Length: 31.1–34.4 in (790-875 mm) * Overall Height w/Mag: 9.1 in (230 mm) * Overall Width: 2.6 in (65 mm) * Stock Style: Adjustable Telestock * Trigger Type: Single-stage * Trigger Pull: 6.6-9.9 lbs * Safety Type: Manual * Principal of Operation : Blowback * Muzzle Thread: M8x.75 * Length of Pull: 13-7/8 IN * Sight Radius: 14.8 in (375 mm) * Diameter Rear Sight Aperture: .06 / .2 in * Front Sight: Width .08 in (2 mm) * Weight w/out Mag: 6.0 lbs (2700 g) * Weight of empty Mag-30 4.2 oz (120 g) * Features: Full metal body, Flat top receiver, Rail Interface System I ran 5 rounds through her and put it in the safe. Includes extra mags pictured I have the original box $525.00 ftf If interested, please contact me @ skiffjunky@yahoo.com
