1 - 3 of 3 Posts
I found a good deal on a CMC PT-130 hydra. tilt and trim unit on CL. I have a 20hp Johnson on my 14ft skiff, I know that the PT-35 is rated for 35hp and under engines but can I use the PT-130 for my 20hp?
First let me ask what is a good deal, cause I just got my new CMC PT-35 delivered for $480. Next yes you can use it, but you will need to buy the clamp on motor adapter plate to use it. Only issue I see is the weight, it has 1/2" more set back and weighs I believe 45lbs :eek:. The PT-35 is only 24lbs.
1 - 3 of 3 Posts
