A Clutch 8 wt 9' Archipelago fly rod is for sale. Clean ing used little. I broke the tip i/2" behind the tip line guide. However I carefully removed the piece of rod in the tip guide and used the correct glue to heat and secure the tip guide back onto the rod tip. It appears that the rod casts as it should. I have found that the rod is just a little too fast for me. I'm not selling it because clutch went out of business it's just the speed issue.
If any of you have the same rod but need some repair parts this might help you.
$ 250.00
text me at 843.929.9108
Blackloon
$ 250.00
Blackloon
