Cavitation plate depth?
1 reading
16K views 10 replies 5 participants last post by  firecat1981
The less lower unit there is in the water, the less wetted surface you have, the less friction you end up with.
Cav plate height depends on the hull shape and propeller.
Flat bottom hulls trap aerated water under the hull and this makes it difficult
for factory props to get a clean bite in the top inch and a half
of the water coming out from under the transom.
In this situation the engine is usually mounted so that the cav plate
(really the anti-ventilation plate) is 1/4 inch below the bottom of the hull.
On a vee hull the starting height is with the cav plate 1/2 inch above the bottom of the hull.
The reason being that the water coming out from under the center of the hull
has less aeration due to the vee shape.
Deeper means better bite at hole shot.
Higher up means better top speed by 1-2 mph.
Is it worth worrying about? How often or long do you run all out?
My typical speed on the water is about 3/4 throttle, the comfort zone.
