I’ll be running a parallel blog on the website for all this, but I wanted to throw a down/dirty version on here as well:
Plug Construction began for the skiff on 12/5, beginning with the build of one big-assed table, 16x5.25. Level to as was not so important as being flat, as the CNC/CAD work we did beforehand pretty much ensures that the angles will be what they need to in relation to all the parts. Flat was far more difficult to achieve as finding a straight piece of lumber at Home Depot is impossible. In retrospect we should have had the longitudinal table beams (2x4x14) planed straight and to even widths, as well as the lateral joists. In reality we spent about three hours with a T-Square and a flashlight looking for any waves in the top as it was screwed to joists, then evening these out with a combination of wedges and screw pressure. No real pictures of this.
After that we threw all the CNC parts together (30 total), just to get an idea of how everything fit. Very surreal at this point to see six months of planning suddenly come together and start looking like a boat with less than five minutes of assembly. Had major issues with alignment of parts when we sighted down the keel. The bulkheads are symmetrical in their outer dimensions, but the registering grooves are not, meaning each piece essentially has a bow side and a stern side. We did this to help minimize the amount of MDF needed (only four sheets for the whole boat). We just forgot we did.
Next morning we began the process of closing in the central “coffin box” and excess spaces with 1/2” OSB. Part of this was done to minimize the foam usage - internal volume is 46ft^3, just the coffin box alone cuts 23ft^3 of space out. The other benefit was additional strengthening of all components, which by this point were glued to the table. Biggest issue here was the incredibly slow cure time of wood glue in the 50-degree temps. Eventually we switched over to standard gorilla glue which cured in about 1/4 the time. Even with a propane-powered torpedo heater running full-time (plus a CO detector) we were unable to achieve decent cure times on the wood glue - surfaces just stayed too cold.
As of this afternoon all major voids have been sealed off by OSB. The additional large cavities will be partly filled with scrap lumber laying around, cutting as much spare volume as possible, before expanding foam gets poured into the remaining space. Then begins the shaping/sanding process prior to everything getting a 3/4oz mat layer laminated over it.
I’ll throw some additional stuff into the blog when I get around to it, or you can follow along on instagram @PropGunOne. Hoping to get some foam poured tomorrow if we can get the climate control under... well... control.
TTFN
TTFN
