Sounds great
might make a great removable Deck !
Overlaid Plywood
MDO Medium Density Overlaid
MDO Plywood - The Paintable General Purpose Panel
Characteristics: An EXTERIOR type plywood with a weather-resistant resin overlay bonded to the wood by heat and pressure. This process fuses the molecules of the overlay with the fibres of the wood to form a bond as strong as the wood itself. MDO has all the advantages of regular plywood as well as additional properties. The overlay, which has 28% resin content, resists water, weather, wear and degradation. It has texture that paint can grip with remarkable tenacity. Paint finishes on MDO are up to three times more durable than the same finish applied to ordinary plywood.Ideal for Painted Signs: In many instances, overlaid MDO plywood has proven a more durable sign material than metal. MDO plywood is resistant to the elements with no danger of rust or corrosion.
