1 - 10 of 10 Posts
I just bought my first microskiff and am planning some changes. The first is I want to remove both bench seats and build a small center console with a grab rail and a storage area / seat on the front. I am new to the world of fiberglass work but have woodworking experience. Once I build what I want out of wood how do I make it so that I can pull a console from it? Pictures will come soon of the boat and during the rebuild.
Most important part...mold/plug has to be tapered
wide at the bottom, narrow at the top, otherwise
the fiberglass layup won't come off...
                   seen that happen a couple times... :D
How fancy are you going to make the console?
Gloss finish or workboat finish?
http://www.fgci.com/howto/ht003fiberglass_mold.html
I really like the gloss finish but like I said no fiberglass experience. So which ever is easier. I still need to do some research maybe read a book or 2 and seek out some videos. I am thinking something simple like the one Mel uses on his Native skiffs only a little taller.
I built a console mold for a 17 whaler using half inch plywood,
pine 1x2's and formica. Came out pretty smooth.
The formica was glued inside the plywood shape
so the fiberglass layup matched the finish of the formica.
For a one off mold, the best thing I have found to use is melamine covered MDF. The same stuff cheap cabinets are made with, Home Depot usually keeps it in stock. Don't forget to radius the corners inside the mold, for a small radius modeling clay works pretty good. You will also need mold release wax or PVA in order to get the piece out of the mold.
Classic Mako and Classic Sea Craft sites both have pretty good builds that show mold making for one off parts, and if you have time it might be worth a look......
A great way to have the piece to release from the mold is plastic. I use the slightly stretchable stuff that you put on the floor when you are moving to protect the carpet. It has a light glueing on the back to hold it in place and you can stretch it to make a real smooth surface. The stuff comes on a roll from the box stores for about $12. Also use the plastic packaging tape to secure any of the edges that may need attention.
Plays with Glass...
This is how we did a lot of our plugs at the prototyping shop I worked at.
However, melamine is CRAPPY for anything under vacuum.  I ruined a 3'x3' epoxy divinycell layup by pulling air through the MDF.  Lesson learned I guess.
1 - 10 of 10 Posts
